Need exhaust clamp
Lifetime Member
Lifetime Member
Need exhaust clamp
We are trying to find parts for the IG Inc exhaust system. Basically Shenandoah Circuit ate one 'Olive Joint' Clamp. I am trying to locate a source for these since it appears that the clamp will be a consumble item unless I put FIA planks under the exhaust or don't drive the Shenandoah Circuit anymore. The joint appears to be made of four parts, two flange parts, an internal gasket/bushing (lower right) and a clamp. The pipe may be merely expanded to take the internal gasket/bushing thing. The pipe is 2.5 inch stainless.
Alan,
Looks the same as the 964 muffler/cat mounting, using the interior donut and the exterior clamp to hold it all together. Can be a pain to get to seal.... I'd just as soon not pull it apart to see if the donut is 2.5", however, if you want to pm or email me the exterior measurements at the opening, I can measure the outside to see if the 964 parts might help.
