911 Forum 1964-1989
Tachometer bouncing - Ignition missing
Old Jan 1, 2007 | 07:07 PM
Daniel Dudley's Avatar
Daniel Dudley
Don't forget that a little play on the distributor shaft will screw up your points gap, but be fine for installing pertronics. It is always a good idea to wiggle the shaft when replacing points. Also a tiny amount of grease on the rubbing block will keep it from rubbing away and wearing the gap to zero.
