911 Wire Harness Replacements
5th Gear
The PO of my 84 SC was extremely proactive in making electrical changes under the dash. It is an incredible rats nest with T-connectors interspersed throughout. It is hard to fathom what they were all for. I have about decided to replace the ignition switch and headlight switch stub harnesses. Does anyone make those replacement harnesses or am I stuck with either OEM prices or take a chance through a dismantler that their harness is not also hacked or harboring corrosion inside.
I have not checked to see if Porsche even still carries those w/h.
If I end up rebuilding with new wires is there a source that shows the pin outs for the connectors?
Doug
Doug
I suggest you talk with Jeff @ Parts Heaven. 1-800-767-7250. Tell him you want an unmolested harness, and I'm sure you will be happy with the result.
Usual disclaimers; happy customer for 15+ years.
