Brake wear sensor lite won't shut.
I rebuilt my calipers and had some issues with a soft pedal which I resolved as described in my earlier post here titled "Don't ever do this" The sensor pad warning lite next to the emerg brake light came on when I first completed my bleeding and the pedal sank at first to the floor until it firmed up after a few pumps. The brakes are rock solid now but the light won't high tail it away. I disconnected the battery for a while looking to reset the DME to no avail. I pulled the connection on the M/C both with the car off and on to no avail. The rear pad sensors are brand new and I re-used the fronts when I did my re-build as they had plenty of life left and the wear sensor wires looked fine. Connections are good it seems on the sensor lines as well. Got any voodoo up your sleeves fellas?
Appreciate it once again!
Gost
Gost
