Can I hurt the value of my car if I paint the engine fan like others have done?
My Carrera is from 89 and is really clean. Will I hurt the value of my car if I have the engine fan painted? I just don't like the natural look and if it's painted red like the body, I think it'll look cool. Pros, cons, please.....
Raj
Raj
Raj - If anyone has a problem with the painted fan (I suggest powder coating, btw), a used replacement can be fitted with minimal expense and effort to restore its "originality". If you really want to be **** about originality, buy a used fan, powder coat it, and replace it for the original (and keep the original for posterity)...
Personally, I think the fan on my car is the worst part, aesthetically. Otherwise the car is pretty much perfect. So, if the PO had gone to the effort of powder coating the fan to match the body, while I wouldn't have paid MORE for the car, I certainly wouldn't have used it as a point to drive the price DOWN, either.
See what I mean?
See what I mean?
![](http://www.l2specialties.com/scott/879115.jpg)
I just did mine and it was only $100 to have prepped and powder coated gloss Red ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I had them mask off the part where the belt contacts the fan to prevent the coating from coming off there. Also had the pulley (part in front of fan) for the belt sprayed metallic Silver...
Originally Posted by M491
Red fans are a bad cliche.
Originally Posted by GrantG
how about powder coating it in Metallic Silver then, to keep the original metallic look?
Ian
I just removed mine and bead blasted the whole thing and sprayed with clear coat. It's been 2 years nowand looks great. Oh, I've since deleted the A/C and back dated the heat.Whatcha think?
The Ancient One
Rennlist Lifetime Member
Ruby Metallic, I love it. Same as mine. Did you blast & paint the fan AND the housing, or just the fan?
BTW, only a poor job will reduce the value of the car, and not by all that much since it would be minimal effort to return it to original if desired.
Originally Posted by tdatk
Whatcha think?
Ian
