More Power from CIS
I have a exhaust gas analyzer and in looking at the manual I notice that maximum engine power is obtained at a rich A/F ratio of about 12.5 to 1, CO level of 5 to 6%. I have a 78SC with emissions optimization by removal (no air pump or cat). Has anyone run a CIS system at 5 to 6% CO for more power? If so, any results to report? I suspect you could also advance the ignition timing with a richer mixture. What you give up is fuel economy, but what the hell....it's a Porsche.
Hi
I would also like to adjust the CO. Where can I get a CO analyzer? By the way it seems to me that the ecu and the O2 analyzer will defeat your
efforts to enrichen the mixture except for startup. Am I wrong? Is there a way to defeat the
ECU to get a rich mixture?
Good Luck John
Good Luck John
The 78's didn't have an O2 sensor. You are right about the ECU function, but that's just one more thing to take off.
Run a web search on exhaust gas analyzers. There are a number for sale. I've had an XKE for many years so I have an old Heathkit analyzer I use on the SU's.
