Best sounding muffler for 911SC?
I'm getting SSIs and I want a muffler that will make the car sound better, ideally, like a GT3. preferably dual exhaust. I've listened to some sound clips of a dansk and i couldnt really tell if it made any difference. There's gotta be a muffler that makes the kind of difference that a flowmaster makes for a mustang.
And they are fairly light - about the same as a Monty in wt.
There are no dyno results on them tho. Or you can pay 2x for a Monty which is known to not lose any hp -- unlike most aftermarket mufflers.
I bought one of the mb911 2:2 mufflers from Ben. It was one of his early units. Mated with SSIs, it turned out to be too loud for the street. It sounded wonderful above 3k RPM, but, between 2-3K, there was a resonance inside the car that made normal conversation impossible. On the track, it's simply awesome!
That said, it's my understanding that Ben is now making the mufflers a bit quieter, and you may even be able to specify how loud you want it to be. He's even advised that he may be able to supply me with some sort of insert to quiet mine down for street use. Right now, I switch mufflers before track events and I bring the street muffler with me, just in case I get black-flagged for ebing above the track noise limits...
As stated previosly, Ben makes a high-quality muffler and it is significantly lighter than stock. I believe mine weighed a full 10 pounds less than my Dansk SS 2:1.
Randy you stated:
"Or you can pay 2x for a Monty which is known to not lose any hp -- unlike most aftermarket mufflers."
Per statements by most aftermarket muffler manufacturers( Dansk, Monty, Fabspeed, etc.), especially sport mufflers claim to "increase" HP. Why do you make your above statement? In fact I have never seen any documentation showing that by using aftermarket mufflers you lose HP. Can you document? Just curious as this is one upgrade I was considering down the road.
I just replaced my stock cat and muffler with GHL's sport cat and muffler. I don't know whether it's the sport cat or the muffler, or both, but the car is noticeably faster. And sounds wonderful too.
I have SSI's and a Monty dual out muffler on my 82 SC and I love it! The large dual outlets not only look good on the car, but the sound is like a performance car. I agree, it is a louder, but worth it in my opinion. With luck you can find one used on one of the sites.
Chris
1982 911SC
Chris
1982 911SC
Jim - this is in various columns by Bruce Anderson and maybe his book. Not to mention the feedback I've gotten orally on this from Jerry Wood and various other race engine builders. MFI is a whole 'nother issue too.
Be careful when you read any claims. The 'increases' are usually over a stock Carrera exhaust NOT the 'stock '74 and earlier system. Also, most hp benefit comes from changing the heat exchangers back - lots of threads on this if you do a search here and at pelican. But - obviously, be careful whose opinon you trust on the internet... BTW, the Dansk is just a copy of the stock muffler design.
BTW - people are not distinguishing the two types of dual outlet mufflers above. The ones with straight pipes directly out the rear are much louder than the cow horn types (my Monty for example) which are themselves somewhat louder than the single outlets.
Randy - Thanks for the answer! As I own a Carrera, I have only looked at the Carrera after market sport mufflers and that's where I've seen "claims" of increased HP. Interesting though, I will look at what BA says in his book. The more I read and learn, the less I seem to know :-)
re less.. It's just that there are a lot of exceptions, etc. based on which model year and the type of use. BTW, check re your emissions regs.
They are all 911s but they are all different.
