Advice requested on Carrera 3.2 Valve Job
4th Gear
Hi -
I had started a thread on evaluating a purchase of a 1988 Carrera with 104K miles, and decided to repost as it has become certain this car needs a valve job to rectify worn valve guides. The owner is paying to have this fixed but there is of course discussion of what needs to be fixed.
I visited the shop where the work is being done today. I saw the heads with disassembled EXHAUST valves only and they show guide wear. One of the valves had enough wear that it was not seating cleanly which showed up as leakage on the PPI.
Question 1:
Without disassembling the INLET valves, mechanic expects that these will not have guide wear, and suggests simply removal, cleaning, and re-assembly. Is it just the EXHAUST valves on Carrera's that exhibit guide wear? Should the 6 inlets get new guides and valves even if they show no wear?
Question 2:
The mechanic brought up the subject of installing stronger cylinder/head studs. From what I've read here, stud failure seems more common on earlier SC's, not the Carreras. Is this true? This is the kind of thing the owner probably will not pay for, is it worth the $1000 (parts & labor) to have stronger studs installed for a run of the mill street car (no non-standard mods)? I think not but wanted to check.
3. What have people paid for replacement valves/guides on this kind of top end rebuild?
Many thanks, this forum is helping me get through what for a newcomer is a trying path, but in the end worth it.
regards,
David
Question 1:
Question 2:
regards,
David
Question 1:
I don’t get why this shop does not want to pull the intake valves!!!!. IF it was me and I was going to keep this car I would have them all done at the same time Seats are $12-$16 each a big $48 more to NOT worry about them. On mine some were lose not bad just loseso we did them ALL. What's the labor to replace them? 45min@ $75?=202+48=$250 vs. 2-3K to re-pull it all back down…
Question 2:
stud failure seems more common on earlier SC's, not the Carreras. Is this true? YES
I would not spend the money to do this on a Carrera unless you have a broken stud.
Question 2:
Why tempt fate? Do all the guides (I&E), and replace all the head studs. The cylinders should be measured with a bore gauge, and replacement piston rings should be considered. Resulting end cost is minimal once you start driving the car and amortizing the cost. If you do the studs also consider replacing the rod bearings through the case, just in case that engine oil has gotten real low a time or two.
Pete
Pete
Carrera's have painted divlar head studs on the bottom and steel on the top. They do break, agreed, not as much as SC's but they do. Cheap money now, do the valves and studs.
