MSD Ignition for 911 Carrera?
Legacy Flounder
This may be a silly question, but has anyone done an MSD ignition box upgrade / does anyone know if this would benefit the 3.2L?
I ask, because it occurred to me that if the twin-plug setup is beneficial for added power, wouldn't a multi-spark igntion also be a bonus?
It's probably one of those right-in-front-of-your-nose / RTFM questions, but I didn't see anything in the 911 sections for N/A 911's. Thanks.
I just removed the MSD 6A and coil from a race car we built-we ended up doing the Electromotive Twin Plug ignition on the car. If you decide to go this route-I'll give you this one cheap.
I'll let the 911 experts answer your question as far as performance improvements-I think they are better for the old CIS cars, but I'm testing the limits of my memory (and knowledge) there.
Legacy Flounder
Ben, I suspected the CIS cars would benefit more than the Motronic ones. We have a similar "discussion" in the SHO community, since we use a higher-end (for the day) distributorless ignition system. Some people swear by them, some swear at them.
Are you talking about the TEC-3 system? If so, let me know how you like it, I debated using one on my supercharged SHO track car last year.
Thanks!
Thanks!
"I ask, because it occurred to me that if the twin-plug setup is beneficial for added power, wouldn't a multi-spark igntion also be a bonus?"
The MSD type systems have NO technical merit. It's basically a marketing gimmick
to differentiate the product from other capacitive discharge ignition systems.
The real benefit comes from a twin plug system as Porsche and others have used.
By the time the next MSD spark comes, the fuel charge has been fully ignited.
Bottomline: If the MSD system had any real merit, Porsche and others would buy/use
the technology in a nanosecond. It's a very simple design to implement and would not
add much overall cost to an ignition system. Therefore, its non-OEM use is further
indicative of ZERO merit.
RL Technical Advisor
Fred:
MSD's are fine ignitions and are best suited for cars with imperfect fuel/air mixtures such as carbureted and MFI-equipped ones.
A stock Motronic engine does not gain anything with an MSD as long as the A/F ratio is within spec; the ECU does a fine job here.
Twin-ignition is required for compression ratios at or above 9.7:1 and one uses a Motronic splitter box, 2 stock coils, and a 3.6 distributor to do this. Custom software is also required due to the necessary changes in the ignition advance maps.
Legacy Flounder
Thanks guys, much appreciated on all the info.
Given the A/F below, would further custom tweaking (read: new chip) to lean it out a smudge above 4500rpms do much for this engine, or is it preferred to be more rich on the 911's?
![](http://members.***.net/fhurderjr/images/911/84_911_dyno.jpg)
Fred:
You can do a LOT better in the chip department than Weltmeister.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
That A/F is too rich from 4800 to 5700, but that not the whole story as these tests are all done at WOT.
A better chip will provide much improved results and whats most important; drivability.
So based on this would you NOT recommend an MSD ignition unit for an 82 Euro SC?
I like the performance and drivability of MSD on carbureted and MFI'ed cars since they operate with less-than-perfect AFR's.
That said, if your Bosch CD ever fails, I would consider installing an MSD as a more viable replacement.
The benefits of the MSD would be very modest on your SC unless you opened the plug gaps to .040. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
What's your take on the MSD vs. stock coil while using the MSD box?
I'm not looking for any kind of performance gain (in fact I'm hoping the MSD is legal for stock class racing) but as I'm troubleshooting a starting issue (along with a bouncing tach) it looks like my Bosch unit may on the outs. The MSD seems like a good replacement and is certainly cheaper than a rebuilt Bosch. First step is to install a friend's healthy Bosch and see if it works in my car.
Team Owner
an '82 should not need a tach adapter
the msd can be altered to look silvery if you don't like the orangey red color
OTOH, the Bosch just plugs right in...
BTW - twin plugs ignite a much larger flame front - on a 911 the plug is way off to the side of the combustion chamber (unlike a modern water cooled 4 valve design with the plug dead center) - that's the adv. of twin plugging and one adv. of water cooling
