Spacers--what are potential problems?
I see a lot of talk about adding spacers to fit newer wheels on the sc's or to fill out wheelwells. I've also heard this adversely affects handling and wear on other components--is this true? What does one have to consider when using spacers? Thanks,
Jon
Jon
hmmmmmm...problems......people will look at your car more carefully, it'll look a little more like a hot rod, you'll sit marginally tighter thru corners....ahhh yes problems.
I do believe that some say it may put more load on certain components, but I think your more likely to wear your tough Porsche out in others ways before anything substanial occurs due to spacers.
Maybe someone else with more tech knowledge will weight in with some proof otherwise.
PS for what its worth I have 23mm spacers (rear)on my 87 Cab. Can't say too much about the handling benefit, but it certainly looks nicer with the wheel wells filled out, IMO.
Cheers
Mark
Cheers
Mark
Hello Jon,
Against: Unsprung weight (suspension works extra hard), rotating mass (accelleration and deceleration is affected in the double), incorrect wheel offset (stressed bearings).
For: Looks, wider track (minimal) and brake and/or body clearance.
I'd advice against too big or heavy spacers. For street use they're OK, on track if moderate.
Do remember to use spacers with wheel studs or extended studs. Always tighten the spacers securely.
Regards Tom.
Regards Tom.
