1974 911... Engine Q
Anyway, the car looks pretty complete, if a bit rough. It's had many layers of paint, and all of the body panels look straight. The interior needs a bit of work, but all in all it looks recoverable.
Now, about the engine.... this could be anything from a sticky valve due to sitting to... well, to just about anything. The motor turns smooth so there is some hope for it. The oil cooler seems blown, so they will be bypassing it for testing. The idea seems to be get it running, and see what the compression test shows when hot.
Now, please understand, I really have no say in how the mechanical stuff is being approached. Not my gig. But I'm just curious... what's a decent used(running) motor for one of these beasties go for? Heads? Valve job? Any special tools required for disassembly/assembly? Any major "gotchas" involved other than the usual that one might encounter doing an engine project on any other car?
Sounds like your friend has a long haul ahead but it's great that there are people out there prepared to salvage a mis-treated Porsche.
My response to your question would be to invest in the Wayne Dempsey books - "how to Rebuild & Midify Porsche 911 Engines" and the "101 projects". I think you will find what you need between the two - gives a guide to prices, tools, skill level required etc.
PJC
Wish them all the best in saving the ol' girl.
Used engines: Parts Heaven--ask for Jeff
New parts: EBS (Engine Builders Supply)
