911 Forum 1964-1989
Where is the Idle Adjustment ??????
Old Nov 5, 2004 | 01:20 PM
redidrum's Avatar
redidrum
Default Where is the Idle Adjustment ??????
Anyone know where I can adjust my throttle idle speed on my 1982 Porsche 911sc? Just needs to be bumped up a bit.
Thank You,
Ron
Old Nov 5, 2004 | 03:19 PM
DGaunt's Avatar
DGaunt
There is a large slotted screw on the left (drivers) side of the throttle boday, somewaht toward the firewall side of the engine,just under the air cleaner. sorry, hard to describe. It has a spring over it. It is an air bleed valve and tou (CCW) is faster, in (CW) is slower. Once you find it,You'll always know where it is.
Old Nov 5, 2004 | 03:35 PM
redidrum's Avatar
redidrum
Dave,
Finally got a response. I get my manuals in a few days. Just bought the car weds.. Once I move that big fat K & N air cleaner Ill see it. I didn't know if it was maybe up front. Couldn't see it last night.
Thank You,
Ron
Old Nov 5, 2004 | 05:00 PM
Peter Zimmermann's Avatar
Peter Zimmermann
You do not have to remove anything to perform the adjustment! See my reply on your other post...
Old Nov 7, 2004 | 06:24 PM
DGaunt's Avatar
DGaunt
Something else came to mind: before you mess with the idle screw, make certain your timing is correct. That seems to have more impoact on idle speed than the air bleed screw has sometimes.
Old Nov 9, 2004 | 08:42 AM
redidrum's Avatar
redidrum
Thanks Guys,
I just reached in on the left and backed off the idle a bit and all is good. Tuning her up next week.
Ron
File Type: jpg
Old Nov 9, 2004 | 12:10 PM
Peter Zimmermann
Ron: If that's your car it can definitely benefit from being lowered!
Old Nov 9, 2004 | 12:23 PM
redidrum's Avatar
redidrum
Peter,
Yes, that is my car. I asked about lowering on earlier thread first thing last thursday. Any ideas?
Only had the car a few days. I'm putting my other set of wheels on it first. Have too much work at one time to get it together and need to sell the 928 before my Ex takes me back to court. Tried hiding the 911 !! Too late, I'm busted!
Thanks,
Ron
File Type: jpg
File Type: jpg
