Injector Flow Rate - 3.2L
Anyone know the flow rate of the fuel injectors on the 3.2L engine? Are they low impediance or high?
Also, once that is established would the same injector be a good candidate for use in a custom system to replace the CIS on the 2.7 - 3.0L engine.
Thanks,
Bob G.
Thanks,
Bob G.
I have that info somewhere-I'll see if I can find it. I think I posted here a few years ago to find out, so you may be able to search the archives. Check www.sdsefi.com , they have info about injector types.
I am using these injectors on my 2.2E. They will work fine on a 2.7-3.0 as long as it is not some wild engine. At idle on my 2.2, the duty cycle is around 4-5%.
