84 911 - OIL PRESSURE SWITCH
Problem: Oil Pressure Switch
Details: My Oil Pressure Switch that drives the dash idiot light has failed. I now have an oil leak (drip) at the switch on the engine and the idiot light is on continuously.
Two questions that I need some help with.
1) Can this switch be replaced without dropping the engine? I can see the switch and somewhat touch it.
2) When the switch first failed and the light came on at the dash, it also causes the parking brake and brake pad sensor warning lights to come on. To confirm this situation, I know I have new pads and sensors since I replaced them this past spring and when I disconnect the lead to the oil pressure sensor all the warning light go off. Whats up with that?!
Thanks for the help
Rob
Yes, you can replace the switch by simply lowering the rear of the engine to give sufficient clearance. I'm sure the procedure has been documented at some time on this board. If you can't find it, I'll be glad to write something up for you.
Has anyone come accross a write up on the R/R of this sensor? Mine is stuck a 3.5 bars and needs to be replaced (pressure is OK)
