where is the turn signal flasher in a 911?
I think you will find it behind the oil pressure/oil temp guage. Just slide the guage out toward you while sitting in the driver's seat. Gently pull it away from the dash so you don't inadvertently "disconnect" the spade connectors on the back of the guages. You will then be able to see the flasher just inside the newly vacated hole.
If you are having flasher troubles you can take the module apart and clean the contacts
I took mine apart a year ago and never had a problem since. Mine was silver aluminum
looking and exactly where Richard said it is.
Good Luck !
Good Luck !
