Failed emissions
I have a 1980 911SC that just failed emissions on carbon monoxide.
Here's the stats
HC
133 PPM ALLOWED
45.6 PPM READING
CO
1.64 PPM ALLOWED
2.30 PPM READING
NO
2122 PPM ALLOWED
923.4 PPM READING
Any ideas as to how I can fix this? The car only has 83k miles. Thanks
Here's the stats
HC
133 PPM ALLOWED
45.6 PPM READING
CO
1.64 PPM ALLOWED
2.30 PPM READING
NO
2122 PPM ALLOWED
923.4 PPM READING
Seth,
I have a 77' 930 that failed e-check its first go-a-round too. Heres the trick to passing. Go to e-check early in the morning when they first open, also, you must clean the engine out A.K.A spirited driving, tell the operator to put your car in 3rd gear, maybe fourth with the 915 tranny. Anyway, you might also want to do this after it just rains and the air is heavy. I almost garauntee your car will pass.
best of Luck,
Pete
best of Luck,
Pete
Seth--a couple suggestions:
1) Listen to John Walker
2) If you're due for a tuneup soon--do it first.
3) Run some Techron thru the engine.
4) Get it good and hot before the test.
5) If you have to wait in line--ask the operator to let you run it a little before the measurments.
Good Luck
Good Luck
Seeing as the idle mixture is adjusted by measuring the CO level in the exhaust, I would have your mechanic set the mixture so it will pass emissions, then put it back where it runns best after you pass the test. If you are in California, you won't have to worry about it for 2 years.
Am I overlooking something?
Tom
Tom
Originally posted by Seth:
<STRONG>I found this stuff called GRC 'Guaranteed to pass' emissions at AutoZone. Should I try that in the porsche?</STRONG>
I'd be very interested if this stuff works.
