Driving a new to me 911 SC and ran out of gas with tank showing slightly les than half. When full, gauge stays on 4/4 and empties at just below 2/4. Can this be recalibrated?
I have removed the float sensor, the float appears to move easily when I tip the tube. I have not dissembled the tube to clean the inside, is this recommended? Any advice to remedy the situation would be appreciated.
And then replace the nut with a Nylock when you put it back together. When I pulled my sender the nut was gone and the tube was rolling around in the bottom of the tank.
