wingless Corrected Messed Up '86 911 Left Headlight
analyst
The left headlight on my gorgeous new-to-me 1986 911 Carrera Targa was pointing waaay up and to the left and the adjustment screws would back out instead of changing the beam location.
Removal of the left headlight assembly had LOTS of head scratching (even less hair now) until I also removed the right assembly for side-by-each comparison.
The adjustment screws act upon a threaded bracket on the moving part. It appears that bracket was cold staked by the factory to the moving part, at some point the bracket broke free and that the bracket was reattached to the fixed part instead of back to the moving part.
The bracket was removed from the immobile bucket base and then reattached to the correct location, those headlight assembly (ies) reattached to the vehicle and the beams adjusted to a good ballpark placement. All is working normally w/ the adjustments now.
While everything was apart I noticed each headlamp assembly had an unpopulated miniature bayonet bulb socket. That socket would illuminate the Ba9s bayonet bulb when the parking lights and the headlights were on. Does this extra headlight bulb have an official name?
Those empty sockets were populated w/ a pair of Sylvania 1816LL 4.3W bulbs prior to attaching the headlight assemblies to the vehicle.
Note those ell shaped wire springs that retain the perimeter of the headlight bucket to the exterior trim can be a butt pain to install. It's nice and secure now.
You are too close to the wall for correct adjustment. The procedure is in your owners manual. Or should be maybe for the US it is not there. John Audette might have it on his webpage.
wingless (09-07-2023)
analyst
Very interesting that these Ba9s bayonet base bulbs don't appear in the Bentley Publications 911 Carrera Service Manual wiring diagrams
Is there a name for these bulbs?
What country(ies) get this bulb?
City lights
