Oil issues
Hi guys/gals, I had the '91 911/964 3.8 turbo out for about 45 minutes. It is driven infrequently, 82,000miles. Engine was converted to a TT about 12,000 MILES ago. I let it warm up for 30 minutes, checked oil and it was barely on the stick. I added nearly two quarts while running. Smoke was coming out of the dip stick opening and the oil fill opening WAS FULL to the brim. I tried to change the oil after the last drive and the port in front of the passenger rear was mostly impacted, probably got only a pint. The block drain was clear and drained as it should. In 97* weather, the engine temp was NORMAL while driving. The oil temp Guage was normal, oil pressure Guage was 1/2 way. Any thoughts? Many thanks, Spend911$
Team Owner
sounds like you turned the engine off while checking the oil instead of having the car idling.
Regardless this is the wrong forum for that car, that car is a 964, this forum is for 911s ( built up until 89)
