Oil Tank Sender Gasket Replacement
1986 Carrera
Had the rear wheel off and noticed a bit of weeping around the oil tank level sender so I’m going to replace the gasket and wondering where the level would sit when the engine is cold. Hoping to not have to drain the oil otherwise I’ll just do it at the next oil change
thanks
thanks
Team Owner
i did mine a couple years ago and i dont remember draining the oil. also when you check cold the level is off the bottom of the dipstick so would tell me its way down. i wouldnt be too worried about it ..
I know in an SC tank if the oil is at the bottom mark of the dipstick it will be just below the sender hole and you can change the sender. Halfway up and you will lose about a quart. YMMV
Team Owner
That may make sense as i burn about a quart every 5K miles and i don't add obviously if i have an oil change coming up . I would likely have done it then ( as you have to take the back wheel off ) , then dropped it back onto the wheels to do the oil change when done.
Also note there are different amounts of travel on different senders. My sender from '78 has less travel than the sender my friends '70 new replacement sender, which was interesting and may be related a change somewhere I believe in the 70s to a different dipstick.
Not sure about 3.2 tank, though I suspect it's the same capacity and shape as the SC. The SC sender I have it the upper one below.
Team Owner
i replaced my sender about 12 years ago and the one i ordered required a different dipstick which oi ordered .. what was very interesting was the max line on dipstick was a lot less than my old one. The oil level gauge also matched this perfectly. My thinking at the time was this was done by Porsche due to the oil spilover when at the full mark during high G turns causing smoking. I always fill to the max now an NEVER worry about over filling.
Thanks for sharing. I have the old one.
