Case bolt torque 1971 911T
Looking for the outside case bolt torque specs for a 1971T. I have a small oil leak at the seam and I want to check the tension to see if it can be eliminated. Thank you. John
Do you have the small spec book? It has this. Mine is packed away atm…
Team Owner
one thing about case seam leaks... i would be very careful , here . small oil leaks will always go to the seam as its the lowest spot. I would try some dye to be sure first as thin small oil leak can be hard to spot but will always go to the seam.
In a pinch, I have found this to be accurate when I didn't have the spec book or other source handy: http://www.torkspec.com/torkspec.aspx
eg: http://www.torkspec.com/torkspecme.a...-2.4L-143ci-F6
I believe that is not correct: That sounds like it's for the M10 crankcase through bolts, not the OPs pictured (M8)13mm lock nuts around crankcase (there are 22 nuts). I believe the spec for the 13mm nuts on a 2.2 is 23 n/m, or 17 ft/lbs.
Good to keep a reference for maximum torque per bolt size/type handy to double check any torque spec you look up, or if you can't find it. There are different specs for dry and lubed but these are in the ballpark. Generally the bolts on the 911 are 8.8 grade, though there are exceptions.
Team Owner
perimeter case nuts ( M-8 ) are 25 N/M
