valve adjust question
why is it (or isn't it) important to adjust the intake and outake valves of each cylinder completley before moving to the next?
Couldn't you adjust the intake valves first then the outake valves on a second pass.
During the valve adjustment procedure, does one adjustment affect the other?
RL Technical Advisor
Its simply a matter of expediency. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
You can do this job either way, but one charges a client for the time it takes to do something, its more efficient to do both valves on each cylinder simultaneously.
