1985 911 miss fires when warmed up
Hi, New here, Hoping to get some help. I have a 1985 911 that runs perfect till it get all warmed up. Once it gets warmed up or hot it will start missing mostly at lower RPM's. Very frustrating. I have changed the coil thinking it might get hot and miss. Not better. A friend mentioned a head heat sensor might be bad. I'm not sure wear that is located. Any and all advice would be appreciated. Thanks
skidrdan (11-02-2021)
Team Owner
there is a much simpler aproach to this problem.
when it starts misfiring, stop it and open the engine bay, you will see 3 white connectors to the left. the top one is the CHT sensor, do not disconnect it but short it out across the posts with a paper clip. restart engine.. if it stops misfiring and runs fine it is the CT sensor that is bad.
( jumpering it out simulates a hot engine and leans out the mixture )
Originally Posted by theiceman;[url=tel:17761154
17761154[/url]]there is a much simpler aproach to this problem.
Team Owner
I have located the plug you are talking about but not sure how to insert the paper clip. Can I insert it while plugged in threw the outside back of the plug and make the contact? Very frustrating dealing with this kind of intermittent problem. Thanks again for the advice.
Just an alternative idea to consider - the AFM, Air Flow Meter, in these cars are known to get flaky. Basically they contain a wiper on a resistive element to make a potentiometer as air flow changes. The contact between the wiper and resistive element can be flaky (giving intermittent performance), and tracks wear in the element as well. Fairly common problem. Very hard to find if you don't know about it. Some good troubleshooting steps if you can catch it when it occurs. I'd search on here and Pelican for details on troubleshooting. Good luck.
You might consider just replacing the CHT sensor, even if your testing shows it as good. They do fail, and are pretty cheap.
Hopefully the advice you're getting in this thread will point you in the right directions to investigate, but you'll probably need to do your own googling to get detailed procedures and write-ups. They're out there.
skidrdan (11-08-2021)
https://rennlist.com/forums/911-foru...d-startup.html
