911 Forum 1964-1989
Oil for 915 with lsd
Old 06-29-2021, 05:25 PM
Freddy13110
8th Gear
Freddy13110's Avatar
Default Oil for 915 with lsd
Hello. I filled my box with swepco 201. Contrary to what I read my box is more flexible when it is cold. Afterwards, when it is at 60/80 degrees, it is harder.
Another problem my lsd seize chatter.fort
What other oil can I use to make it more pleasant
Old 06-30-2021, 02:22 PM
r911
Anti-Cupholder League
r911's Avatar
try any other gear oil that meets spec.
some like Kendall
you may or may not need a rebuild sooner
use of the terms seize and chatter in your post is troubling, so you may need a rebuild
Old 06-30-2021, 03:44 PM
Freddy13110
8th Gear
Good evening, thanks for your answer.
I revised my box less than 5000kms ago during the assembly of my new lsd Gripper. (bearing synchro wolf tooth)
Unfortunately I am in France and Kendall is not available ...
Old 06-30-2021, 08:06 PM
r911
r911's Avatar
anything that meets the spec. will be ok
I would talk to the person who rebuilt the transmission as the words you used in your original post suggest problems - could it be translation issues instead?
Old 07-01-2021, 02:13 AM
Freddy13110
8th Gear
Box works fine, just feels dry on hot, 60 ° C 176 ° F and lsd slamming ...
I expected better with swepco 201 ....
Old 07-04-2021, 12:34 PM
Freddy13110
8th Gear
Hello. I finally emptied my box ...
As I am a little disappointed by the swepco that some advise I returned to see the technical review of Porsche for the 915.
Porch recommended SAE90 API GL5 MIL-L2105 B.
So I searched and found Motul 90 PA.
I filled in and tested this day. Great !!!
My lsd no longer slams and my box works much more flexible.
I think Swepco is certainly very good for the circuit but in everyday use it is too firm. my its my experience, Sorry for my English, Google translation is working for me ...
Old 07-05-2021, 11:21 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,160 Likes on 831 Posts
Freddy I have LSD and fairly rebuilt box with new synchros brake bands and Dog teeth . I use swepco 201 without issue , but i do find your problem interesting.
i might research Motul and try it just to see..
Old 07-05-2021, 04:33 PM
Freddy13110
8th Gear
The oil is Motul PA 90 , (Google translate Motul pensilvany).....
Old 07-05-2021, 04:35 PM
theiceman
Team Owner
theiceman's Avatar
What seasonal temp swings do you deal with there Freddy ???
I typically can run -10C here to +30C
Old 07-05-2021, 04:47 PM
Freddy13110
8th Gear
Currently there are 30 degrees (south France)
I put a temperature sensor on my box with indication on the board. I also installed the pump and the lubrication rail
With swepco from 60 degrees the box becomes unpleasant.
Old 07-06-2021, 01:28 PM
theiceman
Team Owner
theiceman's Avatar
so you have a Carrera ? I think the Carrera's have pumps and coolers . My SC does not.
Old 07-06-2021, 06:41 PM
Freddy13110
8th Gear
Yes it is a carrera box, but I replaced the pump with an electric one to better control the temperature.
Old 07-07-2021, 08:43 AM
Daytonacoupe66
Daytonacoupe66's Avatar
Hello Freddy; Motul 90 PA is a L2105D whereas you mention Porsche recommends an L2105B. Did you research the difference between a "D" and "B"? Curious as I have a similar issue - transaxle is fine when cold but when the car warms up the transaxle doesn't like sharp corners, particularly when making a turn from a stop. It grinds. I've tried Kendall and Swepco but no improvement.
Old 07-07-2021, 01:00 PM
theiceman
Team Owner
theiceman's Avatar
do you also have limited slip ??
Old 07-07-2021, 05:09 PM
Freddy13110
8th Gear
2105B is monograde, 2105D is multigrade but I didn t find 2105B from a known brand.
Quick Reply: Oil for 915 with lsd
