So Doc, about this funny scar I've always had....
I've had my '78SC for going on 12 years now. In that time I've rebuilt just about everything and got help were I needed or had to.
Pretty much had my hands on everything.
However, there is one thing that still puzzles me:
What is this plug-like feature in the top of my driver's side fender?
Anyone seen something like this before?
I'm hoping it's benign....
Just above and to right of Fuel sticker
I only have one guess and I hope I'm wrong.
How is your radio reception?
Well those two are just nasty.....the fuel sticker **might** be removed with some solvent (like Sikkens M600) or even lacquer thinner followed by a light sand/polish....if there is nothing nasty underneath. You might even be able to slowly sand the sticker off, masking around the edges so you do not sand anything other than the sticker until you get to seeing paint...and then go finer and finer grit until you get it all off. Scary for sure......
The funny looking plug is not quite in the right spot for a radio antenna hole, plus those are usually on the other fender for later cars....so personally I think you are stuck with prying it off and seeing what is there. Can you get at it from underneath and see what is visible from the inner fender side?
http://forums.pelicanparts.com/porsc...on-aerial.html
I thought manual antenna = driver's side, power antenna = passenger side.
My '75 had a manual factory antenna on the passengers side and I know that after the electric antennas came out, they had to be on the passenger side as there was not enough room on the other fender.
That's definitely the antenna hole. The odd thing is the plug. Maybe someone added a power antenna on the passenger side and just plugged the manual antenna hole. Or maybe it's a replacement fender and they just plugged the hole rather than welding it shut.
Mar
Mar
Team Owner
i have read many things to the same effect, power passenger, non power driver.
my power is on the passenger side.. dollars to donuts thats an antenna hole,.
Thank you guys for all of the replies.
I should have mentioned that I have a power antenna on the passenger side.
So, might Porsche have installed a fender with a plug from a car that otherwise might have had a manual antenna?
I don't see any evidence of a fender replacement, and the original owner never mentioned replacing a fender. (just a theft-related broken rear quarter window in early 80s)
The "unleaded gas only" sticker is original, and in pictures from original owner. I have a new one to replace it.
There is a similar sticker (not identical) inside the gas flap, which I am replacing as well.
I guess what I'm hearing is nobody has seen one of these antenna-area body plugs before. That is either very interesting, or just concerning.
Pretty doubtful that Porsche would do that, but maybe a PO replaced the manual antenna and plugged it himself.
BAT is a pretty good resource for lots of photos. I searched the completed auctions for Euro 911s. Plenty with antennas on one side or the other, but I didn't see any plugs.
You sure you don't have a Euro car, and the unleaded sticker was a clumsy addition by whoever imported it?
Mark
Mark
That fender has definitely been repainted. You can see the overspray where they masked the black filler between the fender and windshield frame. I suspect that fender was replaced in the cars history and the one they found originally had a drivers side manual antenna, They then plugged the hole and painted it red. I've never seen the unleaded fuel sticker in that location either.
Team Owner
i was going to type all this but saw it here.. dont care what you were told, that fender has been replaced.
