We’ve now officially released our ’73 RS/RSR Style Oil Coolers to the public.
New Part Numbers & Specifications
CSF #8201 Dual-Pass
Overall: 22” L x 4.75” H x 2.25” W
Core Surface: 18.9″ L x 4.72″ H x 2.25″ W
Direct-Fit for Porsche ’73 RS Style Front Bumper
CSF #8202 Single-Pass
Direct-Fit for Porsche ’73 RSR Style Front Bumper
Porsche Fitment
These two new specific oil coolers have custom end tanks with a 45° front angle, allowing them to fit flush inside ’73-style RS/RSR bumpers. The fittings are pointed straight back. For best airflow and highest performance, CSF recommends cutting the front tub to allow for proper air flow, exiting behind the oil cooler and underneath the vehicle. Cutting the front tub will also give clearance to allow adding a rear fan shroud to pull more air through the cooler at slower speeds or while idling.
CSF #8201 & CSF #8202 Highlights
High Efficiency & Rugged Durability Bar/Plate Design
M22 x 1.5 Inlet/Outlet Connections
Internal Radius for Maximum Flow
Optimized to Also Accept AN-16 Connections
Triangular Flush Mounting Holes (M8 x 1.25)
“Aero-Flow” Bar Design for Lightweight, Strength, and Maximum Flow
Satin Black Finish for Extreme Protection Against Corrosion and Debris
We know it's been a little while since our last update, but we have more to share. Our 911 was recently feature by Hagerty and wanted to share some of the photos from the shoot as well as the article.
You're invited to experience the CSF 911 carving up California Wine Country for the Official Magazine of Porsche, Type7.
Throughout 2021 our project garnered more attention that we could have imagined. So much so that Type7 approached us with a feature opportunity before the car was even finished.
So when the time came, mere months after the car's debut at SEMA, we knew we had to make a lasting impression. What better way to make use of this opportunity than showing the CSF 911 doing what it was built to - carving up tarmac and looking damn good doing it.
We go behind the scenes of our Type7 Magazine Feature shoot with the CSF 911 Porsche Backdate. Our team shares some of the fun and frustrations of such an endeavor. See the CSF 911 like you've never seen it before!
Even though many people think of printed media as being a bit outdated, one of the most exciting things for any owner is to see their car in a printed publication. The CSF 911 was featured in the latest issue of Panorama Magazine and we couldn't be more excited.
Last week was a big week, as we were able to start putting together our engine and transmission along with the new Kinsler ITB setup.
We’re using a Porsche 996 GT3 plenum. We’ve modified it to fit a full Wiggins clamp assembly – shaving down all the unnecessary bosses and shortening the runners by 17mm each to accommodate the Wiggins weld ferrules. If you know anything about Wiggins clamps, you probably have only seen them in their signature purple finish – we were able to work with our plumbing and hose supplier, BMRS, who is a distributor of Wiggins, to get our clamps custom finished in black.
After the fabrication of the plenum, we’ve sent it out to first get polished and will be then sending it out to get cerakoted in our signature steel finish.
Full Kinsler assembly laid out.
Transmission, engine, and ITB setup all installed and ready for Rywire to come in and start mocking up the wiring harness for the Motec M130 drive-by wire setup. The engine case, transmission, and underside of the car have all been finished in factory slate grey.
Close-up of the custom intake plenum over the Kinsler ITBs.
Foam cutout representing CSF’s new ’73 RSR front bumper oil cooler that Wie’ll be receiving the first prototypes of next week.
More updates coming next week on the interior – Stay tuned and have a great Fourth of July!
I 'm surprised you didn't a composite plenum to save weight and barrel valve throttle valves.
With auto events back in full swing this year, we've been itching to take the CSF 911 out and show her off. First show appearance of 2022 was WekFest Los Angeles this past Sunday (August 14th). Wekfest is one the biggest and most respected automotive events in the country. The show is highly competitive with some truly spectacular builds on display. Even against the tuning elite of Southern California, the CSF 911 pulled the award for Car of the Festival and we couldn't be more proud!
The CSF 911 was recently featured in 911 & Porsche World Magazine (Sept. 2022 Issue). It's still available on news stands and for order if you're interested in picking one up.
Ravi Dolwani, the owner of CSF, has pulled out all the stops to reimagine a 1982 Porsche 911 SC into a $500,000 Singer-esque halo car with some of the industry’s best players.
More than just a backdate project, this nut-and-bolt restoration combines old-school builder techniques, intricate upholstery work, modern engineering, and timeless style into one platform.
Initially created to compete in SEMA’s Battle of Builders in 2021, it is still making waves worldwide and helped cement CSF’s legacy in the aftermarket game.
Wherever you put your attention is likely where you will find yourself. Ravi Dolwani, the owner of CSF Cooling, has admittedly put his attention in many places — even behind the decks as a DJ if his Instagram handle didn’t give that away. But where he put his mind nearly two years ago was likely one of his most ambitious destinations: an air-cooled Porsche 911.
As much as this article will end up talking about the project — this 1982 Porsche 911 SC that you see in front of you — Dolwani’s personal evolution, and the loftier expectations that come from that growth, helped shape what this car ended up becoming.
Truthfully, about a billion cumulative mods end up making the CSF 911 special, but at the end of the day, Dolwani really had nothing to prove to us. By this point, he has already created four-figure horsepower 991 Turbos, an S55-swapped E30 M3, several successful track cars, and a business boasting over $10 million in annual revenue. This project meant something more: an opportunity to create a legacy.
WHAT’S BEEN SAID
The Internet can tell you everything you need to know about the car itself. It’s been featured, ogled, and admired by nearly every facet of the globe since its launch nearly two years ago, but it’s worth a synopsis. At this point, it’s just an SC by VIN; everything has been changed, massaged, upgraded, or engineered to be better than it was, and in many cases better than it ever needed to be. A Porsche 993 3.6-liter lump provided the basis for what would eventually become a 3.9-liter, nearly 400whp peach. The body was dipped and lovingly prepared for a plethora of nips and tucks. A special blend of backdated aesthetics mixed with modern flair (courtesy of the one and only Jon Sibal) created a buxom, yet perfectly proportioned exterior.
Inside, nods of Porsche fandom, like the early 911 style green instruments and Porsche Classic radio, wafted a choice effervescence atop the aptly trimmed, monochromatically restrained interior. Yet, staccato blips of energy, thanks to the generous splashes of Goyard fabric and motorsport-derived upgrades reminded you that this was no ordinary 911 — even though it could easily soothe you on an effortless Sunday drive, it could just as quickly bite and therefore commanded respect.
IN A CROWDED ROOM
Regardless of where we’ve started as automotive enthusiasts, it really does seem that, in 2023 at least, all roads lead to Porsche. The brand’s meteoric rise in value has caused people who’ve never looked at the brand before to take notice and all of us who’ve aspired to sample the marque have a real sense of FOMO. Our collective “one-day” aspirations had to quickly become “now or never”. Custom houses like Singer and Guntherwerks, who create six and seven-figure interpretations of the 911, have moved that bar forward even more. Still, even amidst the constant chatter around the marque, the CSF 911 managed to break through the noise and in a lot of ways, do it with more style than the rest of them. Les jeux sont faits.
Part of Dolwani’s success here is a testament to his genius. At this price point, there simply isn’t room for “no”; high-end ownership is accustomed to getting exactly what they want. Dolwani understood this from the jump and every idea — even the craziest ones — became a goal that he and his team were tasked to transform into tangible upgrades.
He recognized what he and his team could do themselves and where he could (and should) lean on his expansive network to achieve his goals.
AN IDENTITY CRISIS
I think it’s healthy to wrestle with how you define yourself every couple of years. What do we inherently like? What do we value? And, crucially, what do our actions, priorities, and choices ultimately say about us as people? Are we even still talking about cars? As I’ve aged, however, that evolution has become less about sharp absolutes and more about softer, more pliable facets. As transcendental as these questions can be, they certainly apply to the automotive world, too. While 20-year-old me was fixated on owning every iteration of M3, my more vintage form has embraced a more diverse range of marques and models.
Similarly, Dolwani’s company may have been synonymous with BMW aftermarket cooling solutions, but CSF has steadily moved well beyond Bavaria over the last handful of years. Today, CSF boasts a portfolio of heat exchangers, intercoolers, manifolds, and oil and trans coolers for JDM, European, domestic, exotic, off-road, and even EV platforms. This pivot allowed Dolwani to apply his exacting formula to a variety of CSF project cars, the ultimate iteration of which became this 911.
A REPUTATION, FORGED
I was admittedly never brave enough to play hooky in high school. It’s not the $8,000,000 Ferrari 250GT California in Ferris Bueller’s Day Off, but I would (patterned vest and all), cross my fingers that Dolwani’s garage would be mistakenly left unlocked on the day that I was brave enough to try.
Dolwani’s work here has cemented his reputation as a discerning, top-tier car builder — a distinction that projects a similarly favorable and sophisticated light onto CSF. Unlike a lot of the more extreme cars that “break” the Internet with trend-following aesthetics (and not much else, frankly), this car is completely and obsessively nut-and-bolt perfect. Like fine timepieces, Dolwani’s 911 is a complex creation that can be wholeheartedly treasured by those in the know. It’d be foolhardy to expect that every subsequent build or project will top this, right? After all, every new product seldom makes the previous iteration obsolete or irrelevant. But it’s a scary thought to know that Dolwani was able to put together a car of this caliber together in a short nine-month span. It makes you believe that he and his team have much more on tap. Anyway, his execution echoes the way that we started this article altogether: wherever you put your attention is likely where you will find yourself.
Wherever that destination may be, rest assured, Dolwani and the CSF team have our attention.
RAVI DOLWANI | 1982 PORSCHE 911 SC
EXTERIOR: Sunroof Delete, Body Dipped to Bare Metal, Steel Turbo Fender Flares, Hand Fabricated Aluminum Duck Tail, Hand Fabricated Steel Bumpers, Hand Fabricated with 959 Style Vents & Custom Carbon Fiber Vanes, Aluminum Hood with 959 Gas Door, Reinforced Rear Suspension Mounts, Reinforced Rear Shock Absorber Mounts, Reinforced Turbo Torsion Tube, Early Nose Panel for Long Hood Latch Panel, Front Tub Cut-Out for Proper Airflow Through Front Mounted Engine Oil Cooler, Custom-Made Carbon Fiber Rear Diffuser, Front Spoiler, & Decklid Grille, All Body Exterior Trim Ceramic Coated by Embee Performance, Antigravity H5/Group 47 Lithium Car Battery – 40ah 1500cca, 16 Lbs, With Wi-Fi Tracker & Built-In CTEK Charger, Body Wire Harness by Kroon Wiring Harnesses, Rennline Billet Hood & Engine Lid Struts, Achtungkraft Billet Rear View Mirror, Ceramic Coated, Car-Bone Custom Built Dual LED Headlights with Paint-Matched Housings, Classic Retrofit Electric Air Conditioning with Classic Retrofit Under Dash Nozzles and Wosp 175 Amp Billet Alternator, Achtungkraft Aluminum Engine Lid Hinges, Anodized, Hidden Rear Body Harness, Period-Correct OEM Green Tinted Glass, full car PPF + Ceramic Coated, Including Wheels, Brake Calipers, and Interior
INTERIOR: Sparco SPX Seats, Modified and Upholstered by Rogelio’s Auto Upholstery Using Authentic Goyard Handbags for Inserts & Details, Streetfighter LA Fiberglass Interior Panels, Wrapped in Alcantara with Deviating Stitching, Authentic Goyard Rear Seat Pads, Alcantara Headliner, Alcantara Carrera Dash with Deviating Stitching, Leather & Alcantara Door Panels with Goyard Trim & Door Pulls, Early 911 Style Green Instruments, Custom Built by North Hollywood Speedometer, German Square Weave Wool Carpets with Leather Binding, Under Dash Area Alcantara Trimmed, Dynamat Double Sound Deadening for Doors, Floors & Ceiling, Titanium & Custom Colored Floor Boards & Pedals By Chasing Js, Titanium & Custom Colored Hardware by Chasing Js, Ceramic Coated Momo Steering Wheel, Wrapped in Leather with Goyard Racing Stripe by Car-Bone, Goyard Trimmed Momo Steering Wheel Adapter, Achtungkraft Radio & Dash Trim, Ceramic Coated, Goyard Trimmed Porsche Classic Navigation Radio, Rennline Billet HVAC Controls, Rennline Billet Headlight & Glove Box *****, Rennline Billet Engine Lid, Hood & Door Lock *****, Sun Visors Trimmed in Alcantara & Goyard by Rogelio’s Auto Upholstery, Repa Seat Belts, Color Matched, Repa 4-Point Race Harnesses (Optional), GMG Racing Billet Harness Retainers, Anodized, Custom Fabricated Bolt-On Roll Bar with Removable Harness Bar, Ceramic Coated & Trimmed with Goyard, Goyard Trimmed Parking Brake Handle, Car-Bone Trunk Lining Kit, Goyard Trimmed, Car-Bone custom laser-engraved fuel bib and billet Porsche gas cap
ENGINE/DRIVETRAIN: Porsche 993 3.6 Liter Base Engine, Ceramic Coated Case, Mahle Motorsports X LN Engineering 3.9 Liter Big Bore Cylinders & Pistons Crankshaft – Cross Drilled, Balanced & Micro Polished, Pauter Lightweight Connecting Rods, Pauter Lightweight Mechanical Rocker Arms, Race Timing Chains, Custom-Spec Purpose Built Camshafts by Webcam, Cylinder Heads – Ported, Larger RS Valves, Race Springs, Titanium Retainers, ARP Cylinder Head Studs, Tarett Engineering Billet Valve Covers, Tarett Engineering Semi-Solid Engine Mounts, Porsche 991 GT3RS Titanium Exhaust Muffler, Valved, Titanium 935 Style Exhaust Tips, Fabricated by SV Auto, Hytech Tuned Headers, Ceramic Coated, Clewett Engineering Serpentine Belt Drive, Fiberglass 911 Engine Shroud Kit, Ceramic Coated Fan Housing & Fan Blade, Porsche 997 GT3 Oil Pump, “Pro Gold” “Ac” Hose Ends & “Pro Gold” “Ar” High-Temperature Polymer Braid Engine Oil & Fuel Lines by BMRS, Dual Engine Oil Cooler System by CSF Cooling, OEM+ Right Fender Oil Cooler (CSF #8168), ‘73 Rs Style Front Center Oil Cooler (CSF #8201), Spal Electric Cooling Fans for Both Engine Oil Coolers, G50 Transmission, Short Bell Housing Conversion by Patrick Motorsports, Ceramic Coated & Fully Restored, CAE Racing Ultra Shifter for Porsche 993 With Custom Anodized Shift ****, Billet Transmission Differential Side Cover, Wavetrac Limited Slip Differential, Sachs Performance Clutch Kit , Aasco Motorsports Lightweight Single Mass Flywheel, Race Steel Synchro Rings, Billet Transmission Bracket, Turbo Drive Axles, Bosch Coil On Plug Ignition System, Motec M130 Engine Management with Numerous Fail Safe Features, Rywire Motorsports Electronics Milspec Engine Harness, Rywire Motorsports Electronics Power Control Module, Kinsler Fuel Injection Porsche Gt Individual Throttle Body Manifold Package with Drive-By Wire & Motorsport Actuators, Kinsler Billet Air Intake Plenum with Wiggins Ferrules, Anodized, Custom Anodized Black Wiggins Clamps by BMRS, AEM Fuel Pump, Injector Dynamics 1050X Fuel Injectors
BRAKES/SUSPENSION: KW Suspension “Clubsport” Coil Over Adjustable Suspension, Tarett Engineering / E.R.P. RSR Sway Bars, Front & Rear, Tarett Engineering / E.R.P. RSR Front Suspension Kit, Tarett Engineering / E.R.P. 935 Rear Spring Plate Kit, Tarett Engineering / E.R.P. Bump Steer Kit, Elephant Racing 935x Triangulated Strut Brace System, Turbo Tie Rod Kit, Stoptech “Level 3 Street” Brake System – 6 Piston Front, 4 Piston Rear, Anodized, Stoptech Vented Brake Rotors, Stoptech Brake Hoses
WHEELS/TIRES: Rotiform Custom Designed 17” Centerlock “CMP” 3-Piece Wheels, Cerakoted centers with Anodized barrels, ceramic coated for protection, 17x8.5 Et28, 17x11 Et 10, Stanceworks Billet Center Lock Wheel Hubs with Safety Pins, Anodized, Falken Azenis RT-660 Tires, Front 225/45/17, Rear 275/40/17
