Adjust window trim?
Adjust window trim?
I have an 1984 that recently got new f/r windows, and there are a couple of places where the rubber isn’t lining up all the way with the body. There are also a couple of places where the trim isn’t in all the way... I was thinking that maybe I should squeeze some urethane into the void to push the gasket out, but are there any other (better) tricks?
use a jigsaw to cut a block of wood to that shape
get some plastic interior trim tools
use soapy water, and the above to manipulate the trim to fit better
put cardboard or hardboard on the glass to guard against errant hammer blows to the wood block
Having just gone through this recently, I will share my thoughts/experiences - but be curious to see what others say.
- The trim has to be seated in the rubber seal channel during the install - if it pops out, you must remove the window and start over. This is a huge PITA.
- The front/rear window seals are known to have poor fitment unless they are OE Porsche. I had this issue - removed windows and reinstalled with Porsche seals and it solved the fitment.
Your method intrigues me. Have you done this with good results?
