Power door locks
QQ:
I have an 88 911 and can unlock driver's side with power locks with the key but cannot lock them. It's the same from the passenger.
Ideas, things to check? Thanks in advance, oh wise ones!
Are you getting 12V to the switch. Sometimes one or more of the wires w/ break where it passes from the body to the door. In me car which I buy on auto auction streaming. If you are getting 12V to the switch, then you need to jumper 12V to the lock solenoid to see if it's working. Or the drives side door switch is not working and preventing the door lock solenoid from working.
pull the switch out and try cleaning it up and reseating the connections.
Todd, Are you able to turn the key at the door or not? I could not turn the key at the door when I was at the airport the other day. Had to lock from the inside whilst in the passenger seat.
Now it works fine.
Now it works fine.
Yes, the key on both the drivers and passenger work just fine. I can turn to unlock it, just not lock it. It's like the connection to lock doesn't actuate but again turns just fine.
Hi Todd, did you ever find cause of the door lock problem? I am a newbie 32 owner and I have the same issue -- the key in the door unlocks the car when turning to the left, but nothing happens when turning to the right.
thx
Jim
thx
Jim
thx Jim
I think I had a similar problem in my '85 cabriolet about 15 years ago. I'm guessing I took it apart, cleaned it and got it working again - no notes of purchasing any parts.
In my car, there are 3 different ways to lock the doors - the key in the external lock cylinder, the red button in the middle of the lower dash console thing, and the round mechanical locking **** on the door. Do any of those work for you? Feeling for how smoothly the mechanical **** moves may give some clues.
Being a cabriolet, and with the top always down, I virtually never (like once a decade maybe) lock the doors, which may be why mine got a little stuck.
Pretty common problem if I’m understanding correctly. There is a linkage arm in the door that breaks after many years. You’d see it if you took the panel off. The arm is superseded to a 964 plastic part that is not adjustable. Changed mine out years ago due to this problem.
