soggy carpet
Anyone have a problem with the carpet in an SC getting wet when the pcar is caught outside in a really good rain? Mine is getting soaked in only one area, on the floor board where the door posts are located but only on the portion where the carpet curves onto the floor.
JJM,
I had that problem, and bad. See if you can follow the trail. Check if you can follow the dampness. I found some water just underneath the rear window. I picked up some silicone sealer and applied it all around the window. The rubber seems to have folded at the corners and allowed water in. Haven't had the problem since. Good luck.
J.Michael
81SC
J.Michael
81SC
