How to change/replace the clutch fluid in an '89 Carerra?
It's time to replace the fluid in my clutch in my '89 Carrera, and I don't have time to be without my car, so I figured I would give this one a try myself. Does anyone know if there are any pitfalls to doing this...or things I need to MAKE SURE and watch out for? Can you use Super Blue racing fluid in the clutch as well?
HELP!
Lush Daddy
HELP!
Lush Daddy
Lush,
You bleed the clutch the same time you bleed your brakes. The Master Cylinder for the brakes also serves the clutch. To bleed it, you need to locate the slave cyliner on top of the trans and bleed it from there. I use a pressureized bleeding tool which makes the job much easier. Oh yea, I use only ATE Super Blue.
