911 Forum 1964-1989
Jumpy Tach
Old Mar 14, 2004 | 11:08 AM
lorenzg's Avatar
lorenzg
Default Jumpy Tach
The tach on my '73 engine is acting strange. After several minutes of smooth running the tack all of a sudden will start to fluctuate between the current RMP and zero. It always seems to run fine for a couple of minutes, then goes hay-wire. It's not the gauge, the same thing happens on an old tach/dell meter. I've installed an MSD system with the tach adapter. I needed to do this when I switched chassis and the old CDI system went away with the old chassis and the CDI with the new chassis was incompatible with the '73 motor. I've swapped coils three times and still have the problem. Interestingly, there is no apparent change in engine sound or audible performance change. Any help in pointing me in the right direction would be appreciated. Thanks, Rich Lorenz
Old Mar 14, 2004 | 11:54 AM
DGaunt's Avatar
DGaunt
I know my tach used to act wonky when my points got out of adjustment. It was the first signal that i needed to adjust them. Then i went to a Pertronix unit and solved that issue.
Old Mar 15, 2004 | 08:55 PM
rfw 911's Avatar
rfw 911
I had a similar problem and I just had the points replaced
and I just picked the car up today, so far no problem.
Also you mignt want to check for fualty grounds, the can
cause all sorts of nightmares.
Regard,
Rich
Old Mar 15, 2004 | 09:35 PM
markwemple's Avatar
markwemple
I'll go with a bad ground. Replacing the straps is one good cure-all for 911 ailments.
Old Mar 15, 2004 | 11:07 PM
lorenzg's Avatar
lorenzg
Thanks for all the responses. I think I'll check the ground straps. This motor was just put in the car and hasn't been driven much at all. The points probably need to be checked also. The strange thing is the motor doesn't seem to be affected with regard to performance.
Old Mar 16, 2004 | 06:30 PM
DGaunt's Avatar
DGaunt
Yes, it's funny, the tach seems to get jumpy before you notice the engine...but sooner or later you will, if you let it go.
