G50 Wevo Shifter rubbing on console
Hi all -
Just installed a Wevo shifter on my '87. It's very nice and a huge upgrade since my sifter was super sloppy.
In any case, I reinstalled the console and the sifter now hits/rubs against the black plastic console housing when shifting into 1st, 3rd and a tad in 5th. Do I just need to slightly adjust the sifter base to the rear? The mechanism also touches the ebrake handle when sifting down into 4th so I'm afraid adjusting to the rear will cause a bigger issue in 4th.
Ideas?
thanks!
Jim
Ideas?
thanks!
Jim
I installed the classic Wevo shifter on my '89 and I had the same issue for a few weeks after the install. I somehow managed to slightly adjust the console housing (pushed it towards the front of the car 1/8") to eliminate it. There was some give when you pressed against the console housing. Initially we contemplated cutting a slight notch where the shifter met the console, but so far the nudge of the console has held and I don't have any rubbing anymore in 1, 3 or 5.
thanks,
Jim
I somehow managed to get the boot housing and the console to work - so it looks like stock - but the benefits of the shifter are underneath. It takes some work - but I can confirm it can all fit without interfering with anything.
Jim
