911 Forum 1964-1989
Rennline Knob Install Q
Old Apr 16, 2020 | 10:39 PM
Rmag911's Avatar
Rmag911
Default Rennline **** Install Q
I just got an 87 3.2L today and It's incredible. I bought some rennline billet aluminum ***** to replace the oem dash *****. I was able to switch out the cigarette lighter **** easily, but the fog light **** doesn't seem to be compatible. The stock fog light **** has bulb inside and a long shaft that screws deep into the dash. The rennline **** is just an end piece that should screw onto something sticking out of the dash. In other words, the stock fog **** has a male connector and the rennline fog **** has a female connector.
Anyone successfully install the rennline fog ****?
Old Apr 17, 2020 | 04:24 AM
911PERVY's Avatar
911PERVY
Yes, unscrew the spindle from your old one!
Old Apr 17, 2020 | 09:38 AM
AG81's Avatar
AG81
Yup........
I have one and Pervy described the fix !!!
Old Apr 17, 2020 | 09:41 AM
Rmag911's Avatar
Rmag911
Originally Posted by AG81
Yup........
Weird, I tried that, but it looked like the rubber was just glued around the bulb housing. Didnt seem like there was any threading to catch the Rennline ****. Ok I'll give it another go. thanks guys.
Old Apr 17, 2020 | 10:42 AM
Rmag911's Avatar
Rmag911
Yup........
I'll grant that I may just be an idiot, but I don't see how this can be done. I even removed the rubber hood. Here are photos of what remains. Does not seem like there is anything to unscrew.
Old Apr 17, 2020 | 11:53 AM
AG81's Avatar
AG81
Rmag911,
I removed the bulb ( yes you lose the illumination if you go this route) and used epoxy on those holes to bond mine to the Rennline ****.
If matching ***** is important to you ( they were to me.... I love matching ***** ) Then this is a fix.
Old Apr 17, 2020 | 11:56 AM
Rmag911's Avatar
Rmag911
Rmag911,
Makes sense. thanks.
Strange that Rennline sells a product that clearly does not work as intended.
Old Apr 17, 2020 | 12:02 PM
AG81's Avatar
AG81
I am sure on the older models it works as intended............ the question should be why is it listed for our year car when it clearly needs modification to work. I did a back date so it doesn't bother me.
Old Apr 17, 2020 | 01:09 PM
Rmag911's Avatar
Rmag911
Epic job! Where did you find shift ***** that fit your wevo shifter? I just received mine and the **** is meh.
Old Apr 17, 2020 | 02:12 PM
AG81's Avatar
AG81
Agree 100%..... I actually made this one. I know it doesn't have as many layers as a lot of the ones out there......... Issue was finding the correct insert
for the G50 Wevo. Happens to be... M14 x 1.5 pitch threads.
Old Apr 18, 2020 | 04:15 AM
911PERVY's Avatar
911PERVY
Sorry, on my 1980 car the spindle unscrewed and was r-used, looks like a G50 is different!
Old Apr 21, 2020 | 09:14 AM
Rennline's Avatar
Rennline
Basic Sponsor
Hey everyone! This is a strange one but I do have some answers. We have found that a very small number of 911's and 930's had these glued stems. I have found them mostly on the fog light *****. I have seen this so far 4x times with varying years of build date (84,85,87). Small batches of different parts is not unheard of for Porsche but I would love the answer on why if someone has it! For the time being I have machined stems for these few examples. If anyone finds themselves needing one please email me and I will be happy to send you a stem --> Russ@rennline.com
WWW.RENNLINE.COM
Orders@Rennline.com
Ph. 213-224-7393
Old Apr 21, 2020 | 10:00 AM
AG81's Avatar
AG81
Russ,
Great that your doing this..... I have an 88 with this issue. I made mine work, but it's not illuminated, and that I can live with...... BTW my 88 was all original so it came this way.
Old Apr 21, 2020 | 10:02 AM
Rmag911's Avatar
Rmag911
Rennline customer service is awesome! I reached out to them about the issue thinking they would just change the compatibility info on their website. They responded very quickly and offered to send me one of the stems referenced above. For anyone reading this thread, they make great products and stand by them.
Old Apr 21, 2020 | 10:05 AM
AG81's Avatar
AG81
Agree with Rmag911's statement. Rennline has always been helpful with issues.
