Help with 1985 3.2 + rear suspension into 1971 911T
4th Gear
Need some guidance on this, I have a 1971 911T that currently has a Chevy V8 in it (the way I bought it) I picked up a wrecked 85 Targa to use as a drivetrain donor and wondering if it makes sense to swap in the trailing arms and rear suspension too. My goal for this car is build it into a 1973 RSR hotrod / tribute / outlaw , I won't be using the torsion bar setup as I'm going full coilovers front and rear. I have to start stripping the 71 and the 85 and start selling off parts to fund the rest of the build....
good thing is that the rear trailing arms are aluminum vs. the earlier steel versions. keep in mind that you will need to beef up the cross member to handle the force from the coilovers. my buddy tperazzo is doing a similar build with his '74. you may want to check out his Youtube channel as he has done a bunch of work to prepare his car for coilovers. https://www.youtube.com/user/tperazzo/videos
I'd lose the coilovers unless it is going to be a racer - and even that depends on the class.
I have Al R. bananas on my '73 (they are form a '77 IIRC) - it is not hard to do.
I also have a 3.2L in mine - with PMO carbs. Also not hard - will you keep the EFI?
4th Gear
During my research, it seems like the later rear arms may widen the track, I'm not sure if there is any other geometry difference that suits modern tires better, I'm hoping there is. I don't plan on tracking the car, but again, from what I have read, coil-overs are supposed to be superior even on the street. I know chassis reinforcements are required and I will weld those in.
I'm going to sell off the factory EFI and going with ITB's and modern EFI, for that I'm going to use a SpeeDuino, might be the first one with such a setup.
coil springs allow the manf. to put a taper into the spring or the winding to alter the spring rate at extreme travel - otherwise, I dunno why they would be superior
coil-overs were used by Norbert Singer to 'cheat' the rules for stiffness w/o actually going outside the rules
If someone says they are superior for street use, I'd ask why
For a street car you can go to a progressive rate spring which will be more supple during normal driving to help soak up little bumps in the road, but still deal with larger bumps with more suspension travel. It also makes it a heck of a lot easier to adjust ride height.
Progressive rates are really the only benefit for a dedicated street car though.
4th Gear
is it a bare tub or will it be?
one of my regrets is not stitch welding my car for stiffness
you can also call up Dave B. (TRE) and ask about some add on pieces to stiffen it - I hear they worked wonders with the "raspberry car" ...
