Brake upgrade -79 911 SC Targa
Hi all,
We are putting an 3.2l Carrera engine into an -79 SC Targa. Engine have ITB's, cams etc. Approx 270-300hp.
We need brakes to suit this build. Will the 3.2l brakes fit right onto the -79?
Is there any other options for upgrade? Front and rear.
Car is on Fuchs wheels, so space is limited. The car will never be track driven eather. So 350mm brakes are not needed.
Best upgrade is still 930 all around
but for your use Carrera 3.2 front calipers and rotors are a bolt on and provide a little more thermal headroom. leave the rears stock to preserve bias
both of the above fit in 7x15 Fuchs or bigger, the 930s will need to have the fins ground down a bit on 7s or use a small spacer, You really want at least 7 & 8 anyway, 15 vs 16 can be debated, 8 & 9.5 is ideal though hard to accomplish in 15 or 16 especially w/ Fuchs
generally street cars don't need anything more than stock brakes w/ good fresh fluid and good pads
Thanks for reply.
Reason we need to upgrade the brakes is by the law. The car needs to be approved road legal, and we then need to have brakes to suit the engine.
So the, lets say, -89 3.2 Carrera is bolt on?
We are going for the KW V3 for g-model.
I do not know the spesifications on the rims now, the car is not at our shop at the moment.
930 Brakes are a great upgrade but expensive. I went another way and have Boxster front calipers on my '83 SC with Carrera rotors for better cooling and the same diameter. I also left the rear brakes original. I run Padgit (sp) blue pads up front and stock in the rear. I did upgrade the master cylinder and have an adjustable brake bias control but it is in the front trunk. The car is tracked ( with my neck not anymore) and the engine is a custom stroked 3.2 developing a minimum of 220 rear wheel hp on a stingy dyne. I do run 16" Fuchs and there is plenty of brake clearance
As far as rules for approval go - we'll probably be fine with the 3.2l Carrera setup at front.
So the origina calipers and brakes from, let's say, a -88 model Carrera 3.2 will bolt right up to the -79 911 SC Targa 3.0l?
yes 3.2 carrera is a straight bolt on swap in front, no other changes are necessary.
SC and 3.2 Carrera use the same 20.6mm boosted m/c so, no, you don't have to change it. Some guys do prefer the pedal that a 930 23.8mm m/c provides but while it is higher and harder(very comforting and easier to modulate) it also requires more leg which some won't like. The 930 m/c is also a straight bolt in swap.
