911 Forum 1964-1989
1981 911sc Gas Smell Question
Old 07-05-2019, 05:00 PM
BoxerJoe
BoxerJoe's Avatar
Question 1981 911sc Gas Smell Question
Hi I have a 1981 911 SC and if I roll the driver's side window down, I get a frequent gas smell, more so when in motion. I replaced the gas cap since the problem arose but it still continues. Any ideas of what could be going on? Thanks
Old 07-05-2019, 09:40 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Hi,
You have a leak in the evaporative control system; the plumbing that connects the tank to the charcoal cannister to control gas fumes. Look for a split or damaged rubber hose.
BoxerJoe (07-10-2019)
Old 07-09-2019, 02:11 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,051 Likes on 748 Posts
yup if your car is like mine the leak is in the hose that runs to the gas tank from the evap canister behind the drivers side headlight under the front fender. tubing was split and leaking.
Old 07-10-2019, 03:04 AM
BoxerJoe
BoxerJoe's Avatar
Cool. I'll check it out. It may be a braided hose. Not surprised that it should be replaced, it's getting pretty brittle from age.
Thanks Guys!
Quick Reply: 1981 911sc Gas Smell Question
