Who Wants to Join Me in Suspension Noise Hell?
Who Wants to Join Me in Suspension Noise Hell?.........
Not me. I've already been there and wasn't having a good time. I replaced everything and it went away.
I'm not sure what it was..... I did all the rubber. shocks, struts, rack inspection/boots/coupler/bump steer kit,Turbo tire rod ends, tie rods, full brakes, strut bar brackets (rear).
No more noise...... maybe not the best method but everything is now new.
I had Zim's in Bedford do the alignment and ride height adjustment after the shocks and struts were installed.
So it took me a heck of a lot longer to get around to doing anything with this, mostly for lack of time but also for not wanting to roll around on asphalt and forgetfulness. Anyway! Here is a video from the front right control arm mount facing backwards. I think the noise is probably clearest in this, but I also took video from the left side as well. None of the videos showed any popping, binding or unexpected motions, but at least you can see the conditions when the suspension creaks. I can almost 100% do it on command by pushing the brakes harder (more brake means more pops linearly) or turning hard enough to scrub the tire, either at low speed or high it will work.
Anyway, if anyone has some other thoughts I'd be glad to hear them. Looking at it now showing no binding at any corner my mind goes towards the steering rack.
Have you pulled your hubs and calipers apart. check bearings, shield, blake tubing, rotor, rotor bolts, caliper pistons, pads, pad springs.
That sounds almost like a pad moving around. The noise is not clear with suspension movement.
nosies suck.
nosies suck.
I've pulled and rebuilt the brake hardware including calipers, as well as swapped out pads a few times. No change. I haven't done it specifically to look for motion in the pads, not a big deal to give it a peek.
Would I lose centering in the steering wheel if this were so? Or would it be more a clamp letting a shaft shift axially in and out? Alignment and steering are good.
Occaaaaasionally I'll feel the hint of something in the steering wheel I get the popping, but it's uncommon enough that I'm not sure if I'm imagining it.
How about strut top bushings? I saw you replaced the control arm bushings but wasn't sure about these. I was wondering if you are getting some movement in the strut assembly.
So with the car on the rack, locking steering rack, grab each wheel at 12-6 and 3-6 and move and shake it you get nothing? Including what was stated above on strict top bushings...
Nothing shaking from 3-9 but a little bit from 12-6, top and bottom. This one bothers me, I've replaced the wheel bearings a couple of times and tried different ways to tighten them up, but they always have just a tiny bit of top-bottom play once I have them tightened up. Rebuilding the strut housings improved this a little but I don't know, maybe worth investigating. It would suck to have spindles or hubs out of round.
I'm only stating the less obvious here....
