991.2 Rear Brake Light in the wing.
5th Gear
Can anyone help with if you can take the rear hi level brake light out of the rear spoiler with the wing in place.
How does the lamp unit come out? Does anyone have pictures for a diagram please.
Thank you.
Thank you.
This is the Air-cooled 911 forum. Suggest re-posting in the 991 water cooled section. Good luck!
5th Gear
The rear automatic spoiler has screws under the plastic caps on the edge facing the rear window. Remover the caps and the Torx screws are then visible. Remove the Torx screws then the spoiler lifts up from the front upwards. The brake light is held in by plastic clips, and it is removable without taking the top off the spoiler. The problem is you will possibly break the plastic clips. Take the top off the spoiler first, its a safer option..
