High Idle Speed in 84 911 When Engine Is Warm
The idle speed of the engine in my 84 911 Carrera is fine when cold, but rises to ~2000rpm when the engine is fully warmed up. What would cause this?
my first guess would be vacuum leak, could also need adjustment of mixture..
this thread on pelican will help you. same exact problem same engine....
http://forums.pelicanparts.com/porsc...2-carrera.html
My troubles from my old thread has helped a few on here, mine wound up being the air meter / sensor, but your's can be any listed....
https://rennlist.com/forums/911-foru...d-startup.html
