911 Forum 1964-1989
Brake pad suggestions
Old Jan 10, 2002 | 04:56 PM
gerry100's Avatar
gerry100
Question Brake pad suggestions
Pretty sure I need to replace the brake pads on my '86 Coupe, I've had this first Porsche 4 months and am pretty sure I'm currently using stock pads. Car is basically a fair weather/weekend vehicle.
I'm hoping to do my first DE or track events this spring/summer and am wondering if I should install upograded pads.
I don't want to break the bank but I'd hate to compromise my track fun to save a few bucks on brake pads.
Any suggestions. Thanks in advance
Old Jan 10, 2002 | 05:34 PM
Thom Fitzpatrick's Avatar
Thom Fitzpatrick
Post
If you're just getting your feet wet in the whole track thing, stock pads with lots of meat will be fine for your first outting. More important than pads would be a complete flush of brake fluid with something like ATE SuperBlue, a close inspection of your other brake components, like your flex lines, and a repack of your wheel bearings. Any one of those will give you more grief on Track Day than not having super zoomy pads.
Old Jan 10, 2002 | 10:00 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Post
Gerry,
Check articles on tech.rennlist.com regarding brakes and brake pads. There are a number of dual purpose pads you can use that will work fine on the street and give you better braking at the track, without breaking the bank. Past that, as Thom mentioned, make sure your brake fluid is freshly bled and that your brake hoses are in good shape. You should replace your rubber brake hoses every 8-10+ years. If you don't know when they were last replaced, I'd recommend replacing them, too.
Old Jan 13, 2002 | 11:31 PM
Tony'z911's Avatar
Tony'z911
Post
gerry100- I don't have much experience, but I use the Performance Friction Pads that came with my '86 Coupe that I purchased a few months ago. They are great street/track pads having great characteristics for each. They don't squeak too much and have good cold braking power. They also work great after they are nice and warm after a few laps on the track! The previous owner said that he had experimented with several pads and found that the Performance Friction pads offered the best of both worlds while still remaining relatively rotor friendly. You may want to give them a try since I don't believe they are supper aggressive, but do offer a nice step up from the stock pads. I would also follow the above advise on flushing the brake fluid and checking your lines.
Good luck and maybe I'll see (pass) ya on the track some day.
-T
Old Jan 14, 2002 | 12:11 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
Gerry, check into the Mintex "C-Tech" pads, there are three levels, all are performance, ranging from what one might refer to as "weekend warrior" to "track-junkie".
I am a full fledged "trackaholic" and made the mistake of using the level one "C-Tech" pads on the track, they worked okay, just okay...my best guess is that they would work GREAT for you as combination street/track pads...as I use them for street driving...and change to the highly coveted (and valued $$$$) Pagid Orange for the track...but in a pinch, they work great for a track weekend.
