911 Forum 1964-1989
911SC Compression Test Values
Old Dec 28, 2001 | 12:14 AM
Hladun1's Avatar
Hladun1
Question 911SC Compression Test Values
What should the cylinder compression test value be for a 1978 SC, US spec 3.0 with 8.5 to 1 CR? I know the leakdown tests are preferred, but a compression test is quick and simple. I also know that the range of values between cylinders is important, but I'm interested in what "new" engine values should be.
Old Jan 12, 2002 | 10:35 PM
driveaporsche's Avatar
driveaporsche
4th Gear
Post
I do not know what the original numbers are, but when looking at a used 3L Porsche, compression should be 130-170 +/- 15%. Leakdown should be 3% - 5% (10% max).
Rick
Old Jan 13, 2002 | 12:54 PM
Hladun1's Avatar
Hladun1
Talking
Thank you. Just what I needed. I assume that the compression values are engine warm and throttle held wide open.
Old Jan 14, 2002 | 12:31 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
Throttle held wide open won't make a difference. The previous values suggested are right on the money...a leakdown test will be much more rewarding from the "informational standpoint"...but you'll need a decent air compressor.
Often I yielded a 160-180lb reading from my SC motor, 9.5:1 pistons...but once I got a 70!! That cost me a few sheckles.
