1988 911 Staggered Wheels Question
I have a 1988 Cabriolet. It has the Fuchs. The tires are 225/50/16 on all 4 corners. Does that mean I have the same size wheels front and rear or was it possible to put the same size tires on staggered wheels?
TIA!
Ray
TIA!
Ray
I ran 8 and 9s on my 89 Carrera
You can stagger
I did roll both front and rear fender lips
Go big
You can stagger
Go big
Did you check left and right. I have a friend who's dad tried to rotate the tires on his 89 and ended up with 2 225s on one side and 2 205s on the other. if you take the wheels off the part number and sizes are forged into the back of the spokes, so would the best for absolute confirmation.
A non-staggered 911 of that era would be pretty unusual.
I agree with all the comments above. Check all 4 tires to be sure they really are all the same, rather than having two rear wheels on the left side and two front wheels on the right side. Then if the tires are all the same, remove the wheels to see if the wheels are the same (16x7 probably). If that's what you have, somebody probably made a mistake at some point. If you do have all 7" wheels, you should then try to swap one pair of 16x7 for either a 6, 8, or 9, putting the wider one on the back of course. More rubber in the rear is important for handling stability.
And while you're at it, inspecting those wheels, probably a good idea to photograph the markings and post them up here. The more knowledgeable people on here will be able to detect a replica, in case you might have one.
The 7 and 8s or 8 and 9s are factory correct options that could be ordered when spec ordering car.
I did with my 89 so I am pretty sure an 88 could have been ordered that way.
Without a build sheet no way to know how car was spec'd
to me 6 and 7s sit so very far under the fenders it looks odd
6 & 7 x15, 195/65 & 215/60
same tires were used on optional 7 & 8 x15
most in the US were delivered w/ 6 & 7 x16, 205/55 & 225/50
only the turbo & turbo look used 7 & 8 x16, 205/55 & 225/50 for '84 & '85, This changed to 7 & 9 x 16, 205/55 & 245/45 for '86-'89
