What changed in '87
#31
Mike
85 - 86
As Jeremy said plus:
4 spoke steering wheel
Central Locking
Antenna in windsheild
Improved shifter (shorter throw?)
Boge gas shocks
Electric drivers seat
for 87 additions:
Did anyone mention:
Rear reflector includes backup lights
Ian
85 - 86
Central Locking
Boge gas shocks
for 87 additions:
Did anyone mention:
Ian
#32
85 vs 86
Good list.
Correction?: 85 on has windshield antenna, yes?
Re: shifter: '86 has 10% shorter throw.
Was there a change in the seats somewhere between '84-87? Higher seat back??
Mike
Good list.
Mike
#34
-Sean
#37
From the Red Book:
1980 Air conditioner
Electric windows
O2 Sensor
Catalytic Converter
Heavier lower valve covers
Trombone oil cooler
3 spoke steering wheel
85 mph speedometer
Bosch CIS K-Jetronics Fuel Injection with Lambda
1981 Cold Start Injection added
Fuel Distributor Non-Adjustable
Halogen Sealed Beams
Steel Fuel Lines
Acceleration Enrichment
1982 Cam Sprocket Bolted
New Alternator
1983 Cab Reintroduced
ROW Body Height
Steel spring-centered clutch (from April 83)
Modified Enrichment
160 mph Speedometer
1984 3.2 liter engine
Bosch Motronics LE-Jetronics Fuel Injection
Finned oil cooler in RF (only some 84)
Oil-fed Tensioners
Integrated fog lights in front
Larger brake discs with warning light
1985 4 spoke steering wheel
Central Locking (US only?)
Antenna in windshield
Improved shifter
Boge gas shocks
1986 Seats lowered
Vanity mirrors
Cabin heat sensor
Larger anti-roll bars & rear torsion bars
Brake light added
Power top
Redesigned AC (larger air vents)
1987 G50 Transmission (aka 950)
Fan & new thermostatic control added to oil cooler
3rd light moves to bottom of window
New transmission
New Shift pattern
Larger clutch
Halogens
Rubber centered clutch
Power top standard
1988 Fuchs replace phone dial wheels as standard
Other convenience features became standard
1989 16" wheels standard
alarm system has blinking lights in lock ***** when armed
Electric windows
O2 Sensor
Catalytic Converter
Trombone oil cooler
85 mph speedometer
Steel Fuel Lines
New Alternator
ROW Body Height
Modified Enrichment
160 mph Speedometer
Oil-fed Tensioners
Improved shifter
Boge gas shocks
1986 Seats lowered
Vanity mirrors
Cabin heat sensor
Brake light added
Power top
New transmission
New Shift pattern
Larger clutch
Halogens
Power top standard
#38
Cut & paste imbedded the dates, let's try again
From the Red Book:
1980
Air conditioner
Electric windows
O2 Sensor
Catalytic Converter
Trombone oil cooler
85 mph speedometer
1981
Steel Fuel Lines
1982
Cam Sprocket Bolted
New Alternator
1983
Cab Reintroduced
ROW Body Height
Modified Enrichment
160 mph Speedometer
1984
3.2 liter engine
Oil-fed Tensioners
1985
Improved shifter
Boge gas shocks
1986
Seats lowered
Vanity mirrors
Cabin heat sensor
Brake light added
Power top
1987
New transmission
New Shift pattern
Larger clutch
Halogens
Power top standard
1988
1989
16" wheels standard
Note:Some standard features in North America were options on RoW cars.
From the Red Book:
1980
Air conditioner
Electric windows
O2 Sensor
Catalytic Converter
Trombone oil cooler
85 mph speedometer
1981
Steel Fuel Lines
1982
Cam Sprocket Bolted
New Alternator
1983
Cab Reintroduced
ROW Body Height
Modified Enrichment
160 mph Speedometer
1984
3.2 liter engine
Oil-fed Tensioners
1985
Improved shifter
Boge gas shocks
1986
Seats lowered
Vanity mirrors
Cabin heat sensor
Brake light added
Power top
1987
New transmission
New Shift pattern
Larger clutch
Halogens
Power top standard
1988
1989
16" wheels standard
#39
OK, what changed between 87 vs 88 vs 89? Any way to ID these diff models from exterior? eg 3rd brake light position, etc?
-Sean
#41
So, how would you spend my $$$ for a late 80's Carrera?
I was focusing on the 87 - 89 cars for the G50 transmission. I've come accross an 86 cab that's "tugging at my heart" (to quote another Rennlister) VERY clean and low miles ~ low 60K range, well optioned.
The big Q: is the G50 THAT much better? Should I just try to be a little more patient and wait for an 87 to 89? I can't drive it until the ice melts here anyway.
TIA,
Mike R.
TIA,
Mike R.
#42
Mike R.
I suggest driving both the 86 and the 87 year cars to determine what you like best. I had an 86 coupe last year that was an absolute blast to drive, the shifting initially requires alittle more patience, but after a few miles becomes very simple. Gearing down to first gear will always be difficult..........but really how often do you need to do that.
Again, drive one of each and decide.
