Any Experience with rear Windsheild replacement?
I thought I had my water leak solved with the Sunroof drain clearing and interior sunroof sealing.
After a slow steady rain for 18 hours, my 1984 Coupe developed a very slight (1 oz) leak in both corners of the rear window. The seal around the window is clearly deteriorated.
I researched the replacement of the seal in the 101 Projects book, and it looks like it is doable.
Two questions: Do you have any recommendations for this project based on your experience, and do you know of any sources for cheaper new seals?
Thanks in advance as always,
Than
Than
