Underneath the Carrera
I plan on powerwashing the underside of my 87' Carrera during the next warm spell but I'm unsure about how far (and deep) to clean. The pan appears to be pretty clean, as I can see the actual body paint color. The wheel arches appear to be coated with a black tar like material. Some scrubbing with a brush can remove this material right down to the painted surface.
Were the wheel arches undercoated this way from the factory or was this possibly done afterwards?
I've seen some cars which appear to have just body colored paint in the wells but they may have been prepared that way for show.
Thanks.
John Pavone
1987 Carrera Targa - 17K miles
Thanks.
John Pavone
Greetings: When I first got my 82, I thought that the black in the wheel wells was also an undercoating. I testing a spot with my power washer and discovered that it was actually 20 years of crud.
I power washed gently and removed most of the grime to uncover the same color as the car (guards red).
However, be care and go easy as you can remove the paint as well. I used an electic 1500 psi unit with more of a broad tip. I found that even with 1500 psi that with a pencil tip you can remove the paint.
The job was also made much easier by jack up each side and removing the tires.
Good luck.
Good luck.
Good point, Buffalo. It could just be just a mixture of mud, dirt and road tar. If it is, the pressure washer should remove it. If undercoating, I guess solvents and/or heat may be required (Ugh..).
John Pavone
John Pavone
John:
The tar-like stuff is a "cosmoline" that they put on to protect the car during shipping. It was applied at the factory, and I believe it was supposed to be removed by the dealer during their prep. I think there's a mixed view about the stuff among the concours folks. Some like to leave it, others remove it.
My car still has it on, but I'm thinking about removing it in the spring. Let me know how you go about it if you decide to take it off.
Thanks,
Sean
Thanks,
Sean
Sean, 3M makes a general purpose adhesive/tar/cosmoline remover. I'll give it a try and let you know how it works out. I've also heard that Simple Green will remove it. I these fail, there's always the pressure washer. ;-)
John Pavone
John Pavone
I don't think that this is undercoating on my car. A quick scrub with just a nylon brush removed the gunk down to the painted surface. It may just be dirt/grease/rubber/road tar which has attached itself to the cosmoline.
John Pavone
John Pavone
Lifetime Member
Lifetime Member
I removed the majority of the cosmoline by spraying the offending areas with engine degreaser, brush, and the commercial high pressure car wash wand. The more recalcitrant stuff came off with Oil Flo Safety Solvent/Degreaser
Also, FWIW, there are many very well thought out articles on taking care of your car at that site.
Originally posted by sschmerg
John:
Thanks,
Sean
John:
Thanks,
Sean
Ask one Concours judge about cosmoline and they'll say leave it on. Ask another judge and they'll want it off the car. It also sometimes depends on the class you have your car entered in.
I've been taught that if the cosmoline is clean, no points should be deducted from the car. It should appear brown or dark tan and not black. The factory applies it, so you should be able to leave it on the car.
Jay
90 964
Jay,
I don't plan on showing the car and since cosmoline seems to attract dust/dirt, off it comes. Hopefully, without too much trouble. Also, a clean underside makes it easier to inspect for leaks and other potential problems.
John
1987 - Carrera Targa - 17K miles
John
Stopped in to see my Wrench 25 year Porsche mechanic said leave it on.......... Out of curiousity I picked a an area and it does come off very easily.
drove the 911 Again IN MICHIGAN!!!
The weather is unbelivible for this time of year!! Next 2 day same 45 or so and SUNNY!! Logged 60 miles today on "my course" On and off ramps M 59& I 75, Getting the hang of drifting pretty good now. Had it up to 135mph, It is addictive. Happy New Year John
jmarenas,
Unfourtunately, my Carrera is garaged 300 miles away (Connecticut) in relatively mild weather and I'm up in the snow (Lake Placid, NY). Maybe the good weather will hold out until early next week, so I can get a drive in!
I've already made up my mind; cosmoline's gotta go.
Have a great New Year!
John
John
