911 (991) Speed Limit Display Currently Unavailable
So I have a 911 C4S (991) 2014 model and I can't get the speed limit display to work, I get the message: Speed Limit Display Currently Unavailable, anyone has any experience with this? And know what to do? Thanks (ps. apologies for the image resolution..) EDIT: Realise this might be wrong forum, please let me know if I should post anywhere else instead
Wrong forum
Get yourself a true 911 (pre-1990) and you won't have to worry about silly electronic gadgets misbehaving
Poseur
Try the 991 forum and they will walk you through the steps to set that up. The PCM is fairly complex but most of that stuff is independent of the PCM and can be done simply through the stalks.
