Not sure why I have this wire running to the dist.
Replaced a seal in the dist. on my 2.7 mfi engine and I noticed a rather precarious wire running to the side of the dist. I wanted to secure it, as it looks rather fragile. The wire has a rather stiff coating that is broken, not surprising after 40 years, but the wire itself is intact. Here is a pic. of the problem area:
Get yourself some black heat shrink tubing and bridge the entire wire. Buy the smallest size you can fit over the end. ....or just run some electrical tape over it.
I wish I knew what the mystery wire is?
