New Product: Steel Porsche Hub Stands for 911
Developer
Description: A commercial-quality tool that belongs in every serious Porsche shop owner's garage. Better than jack-stands, makes working on your car more enjoyable, safer, and faster. Made in the USA, each all-steel hub stand weighs 18.5 lbs. and is professionally painted in a chip-resistant and durable semi-gloss black powder-coat.
As a Replacement for Jack Stands:
Fitment: Fits all cars with a 5 X 130mm bolt circle and a hub diameter of 71.5mm or less, including:
Porsche®: 911, 918, 944, 928, 968, 996, 997, 980, 991, Boxster, Cayman, Cayenne, Macan, Panamera
Audi: Q7
VW: Touareg
Pricing: is per PAIR at $264.70
To Order:
https://928motorsports.com/parts/hub_stand.php
- More secure than jack stands - screwed on - car cannot fall off the hub stand.
- Places center of hub 18" off the floor. High clearance for ease of working under the car.
- Supports the weight of the vehicle where it was intended to be supported.
- Great for winter storage of your car, prevents flat-spotting of tires.
- Not in the way of creepers like jack stands are.
- Designed for vehicles up to 5,000 pounds.
Audi: Q7
VW: Touareg
To Order:
I haddah Google dat
I can't read the first post. Too many fukking pop up ads blocking it. If it does not register in the hub, then weight is supported by the studs, not the hub. The studs do not support the weight of the car in normal operation. The hub does.
Not practical for changing rotors and suspension elements.
Developer
But there are many projects in the wheel well where you would like better access to the suspension adjustment points with the suspension LOADED, like an alignment. Or maybe just because you want more creeper room under the car without kicking jack stands all the time. Or maybe because you want to store your Porsche for the winter without flat-spotting your tires.
