SC front tires
Sher
Addicted Specialist
An SC has the wider rear flare, as opposed to the mid-year 911s, so I'd definitely stagger the f/r sizes. Given that wider rear, I'd double check what widths you have (you still haven't clarified that), and if you don't have 7s in the back I'd absolutely go source some out as the rim widths will dictate what tire size you can put on.
Once you determine that you have 6"F/7"R, put on 225s out back, and 205s up front and you're good to go. Of course you can go wider, but I "think" you're focusing on keeping your cookies, right?
Edward
Edward
15" staggard is the stock spec I believe for all SCs with Fuchs. Agree the wider rears fill out the slightly fared fenders of the SC.
Wondering if going too wide on front tires changes the steering/handling dynamics as intended for the car?
Edward
Edward
Sher-
Team Owner
"going wider up front" will depend a lot on the offset of the wheel you are using , are you thinking same wheel just wider tire ? or changing wheels ?
Addicted Specialist
Pop off a rear wheel and look closely for a stamping. You may have to clean up whatever road grime there, but Porsche factory wheels are stamped with width and offset ("ET" is offset). I've not seen Cookie wheels in a long time but they should be marked.
Edward
Edward
