3.0 SC Weber Conversion Question
I'm just starting to do the switch to carbs on my '80 SC and have a simple question (I hope). I have pulled off the CIS and in doing so was wondering where do I pick up the vacuum source for the power brakes? I'll admit I haven't looked into it too closely, I think there are small vacuum ports on the carbs but this is only from memory and tI think they were quite small. Also I'm running a '79 distributor, do I cap off the vacuum canister on this dist. or do I use it?
Todd
Todd
Todd,
My intake manifolds have a provision for the brake booster vacuum line, but they are made by PMO. If your's are Weber then you may have to drill and tap a hole in order to accept a fitting.You will also need an adjustable fuel pressure regulator if you plan to use the stock fuel pump. You will need to use the vacuum advance, so you can tee it off the brake booster line. I'm pretty sure you can use the existing distributor but you may have to have it re-curved or swap for a '78.
Good luck !
Good luck !
Howard
Thanks for the reply. Could you tell me where PMO put the port for the vacuum.
I already have the PMO fuel pressure reg so I'm set there. The '78 and '79 distributors are the same so I'll hook up the vacuum advance and i should be set.
Todd
Todd
